Question about memory voltage and MSI P67A-GD65 (B3)
vrex
I recently built my system and using a CMX8GX3M2A1600C9 memory kit (2x4gb). The ram is rated to run at 1.65v but after reading forums for a while it seems that 1.5 is what the max is. Is this correct and do I need to buy different ram or will I be ok with 1.65v?
1600 RAM speed @ 1.65v's is your RAM's OC rated speed & voltage. It is the upper considered safe limit for DRAM V., so it should be considered maximum for everyday use. Have you confirmed what the RAM speed & timings are in Windows using the CPUID utility CPU-Z? The Memory Tab & SPD Tab show a lot of useful information, as well as the CPU Tab of course. :-))
When set to auto the mobo sets my ram to 1.65v and in cpu-z it also comes up as 1.65. I'm worried about my cpu burning out however since I keep reading random comments about not running your ram at 1.65 with SB.
CPU-Z SPD Tab is 'Read Only', not active like Memory Tab is. So SPD Tab is only showing SPD static information. To find the actual DRAM V. being set, you would need a digital multi meter & check it at the V-Check point. Your RAM should be able to be set manually in the BIOS to something lower like 1333 speed, timings of around 9 9 9 24 @ 1.50v's. A screenshot of your CPU-Z Memory & SPD Tab's would be helpful.
I guess my question is: on a sandy bridge system will 1.65v on ram damage the memory controller in the long run or not?
Intel's maximum listed for i(x) 2xxxx is 1.575v's. Anything over that is going beyond specifications, & over a long term could/maybe/possibly reduce the lifespan of the CPU IMC. There is no danger of taking high or very high 'rated' RAM & running it at a lower speed or voltage. I do that all the time. :-))
