jdetnersk150802d6
- Feb 22, 2021
I have been using an ASUS motherboard in my gaming rig for a while now and have had issues running my memory stable at 4K speeds and need to manually set the speeds back to DDR4-3600 for it to be stable. I'm currently trying to run 4 sticks of G Skill's F4-4000C18-8GTZ memory (certified in the MOBO's QVL to run in this config) and have worked with both ASUS and G Skill tech support adjusting timings and voltages with zero luck while both blame the other for the issue (90% sure its the MOBO due to symptomology). I recently acquired a 6800 XT to upgrade my rig and am revisiting the memory issue to try and optimize my rig for peak performance with the new GPU. So my question to this forum is this:
Can the MPG Z390 Gaming Edge AC run all 4 of my memory modules at 4K speeds and maintain stability? The Memory QVL would suggest no because it only certifies 2 at a time but wanted to put it out here to the people that actually use the motherboards for a solid answer. Any help would be appreciated, looking to make my purchase soon but am holding back until I get confirmation from other users. I have attached a text file summary of my components created with HWiNFO64 for those with specific hardware questions.
