radix axe6600/graxe66 dashboard-wireless client no long lists devices connected by wifi.
pcguru2000
Any idea why my wireless client list is showing "-2" (is that negative 2?) instead of all my wireless devices? I use to have about a dozen wireless devices that show up here. My wireless devices are getting internet/working fine, they are just no longer being listed in the dashboard under the wireless client.
Around the time this happened, I was just disabling some devices (via the checkbox) that were no long being used in the dhcp reservation list. I also tested turning on the guest mode, and setup new guest SSID's to test if I could isolate some devices from my lan. When I couldn't get a device working on guest mode, I re-disabled guest mode to try it out at a later time. A day later or so, I check the dashboard on my cellphone and I see the -2 next to the wireless client button and there's nothing listed. Thinking there was an issue with my cellphone browser, I logged into the router via my desktop pc browser and saw the same thing.
I've tried rebooting, reloading the 723375 firmware, clearing out devices in my dhcp reservation that were no longer being used, and nothing has changed. Besides "reset router and restore config" is there any other suggestions?
I have about 30 devices (lan and wireless) reserved with dhcp addresss via the advanced, lan, dhcp menu. I don't do anything like port fowarding, and I've disabled qos (ai, traditional, bandwidth).
