F
Falcon
Guest
Hi peepz
i've got an MS 6380 K7T266 Pro-R
AMD TB 1400
512 DDR
2 40GB Maxtor HD's (identical)
Now i want RAID 0 Stripe,
so i format, 1 drive of 80 GB is detected
then when i want to install my OS
i get an error (every time i try there's a different error)
i tried installing WIN 98 SE, Me and XP
Anybody know a solution for this?
TNX
AMD TB 1400
512 DDR
TNX
This will show all the disks connected to your system. Assuming that you are setting your RAID 0 as the C: partition (?) you'll have to format your second drive here, then delete the partition, and resize the C: partition to the correct, maximum size, denoting the storage of both drives as a single one.
