mult.denniss15a202df
- Jul 29, 2026
I have a problem with sudden hard power-offs on my Raider A18 HX A7VIG after a recent firmware update.
**System information:**
- Model: Raider A18 HX A7VIG
- BIOS version: E182KAMS.10D (2026-06-26)
- Windows 11 (build 26200)
- Graphics mode: MSHybrid
**Problem description:**
After receiving the BIOS/EC update (came through Windows Update), the laptop started performing hard power-offs (complete loss of power).
Event Viewer shows:
- Event ID 41 (Kernel-Power)
- BugcheckCode = 0
- Event ID 6008 (previous shutdown was unexpected)
This is a pure power cut, not a BSOD.
**Important details:**
- The issue happens **only when running on AC power**.
- On battery the laptop works normally.
- The shutdown can be triggered by:
- Entering the Windows PIN
- Launching Opera browser (especially with hardware acceleration enabled on the discrete GPU)
- Microsoft Edge and Google Chrome launch without problems.
- Adobe Premiere Pro works fine under load.
- EC Reset was already performed.
**Current workaround that helps:**
- MSI Center set to Balanced mode
- Opera forced to Integrated Graphics via NVIDIA Control Panel + hardware acceleration disabled in Opera settings
With these settings the system is currently stable, but I am concerned about long-term reliability, especially when working with professional software (Adobe).
Has anyone else with the A7VIG (or similar A18 HX models) experienced hard power-offs only on AC after the E182KAMS.10D firmware?
Is MSI aware of this behavior? Is a newer BIOS/EC planned?
Thank you.
Event Viewer shows:
- BugcheckCode = 0
Thank you.
