Doc_Bucket
- May 12, 2022
Yes, I have the same feeling. I have to go by intuition to a certain degree, that's what I've learnt this time.In WinRAR bench, i usually see pretty quickly if a run is quite "underwhelming" because of some background load, then i abort it and start it again (often a couple times) until i get numbers that make sense. If you want to average the numbers, it would be best to exclude the runs which are clearly too low because of something else going on. However, a 40 points difference at such a high amount of points, if you translate that into a percentage, it's almost nothing. If we then also apply a margin of error, these two setups result in an equal RAM performance, so i would choose the one that the memory system is more comfortable with (less voltage and better RTLs/IOLs).
In any case, this thread is blessed with your knowledge and experience, it makes things possible.
