Ram only at 2667 on my H410M-A PRO (MS-7C89)
DoinitSideways
Hi All,
I have learnt the H410 wont support my 3200 DDR4 above 2933mhz (as that is what the board is limited to as it is bound to the CPU... or something like that as MSI support explained)
The issue i have is that in the BIOS settings i only have the option of 2667 and lower... i cannot for the life of me find 2993... and auto mode runs them at 2133 (or somewhere around that)
Ram is (2x16) G.Skill F4-3200C16-16GVK
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR4
Module format UDIMM
Module Manufacturer(ID) G.Skill (7F7F7F7FCD0000000000000000)
SDRAM Manufacturer (ID) SK Hynix (AD000000000000000000000000)
Size 16384 MBytes
Max bandwidth DDR4-2132 (1066 MHz)
Part number F4-3200C16-16GVK
Nominal Voltage 1.20 Volts
EPP no
XMP yes
XMP revision 2.0
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 10.0-10-10-24-34 @ 727 MHz
JEDEC #2 11.0-11-11-27-38 @ 800 MHz
JEDEC #3 12.0-12-12-29-41 @ 872 MHz
JEDEC #4 13.0-14-14-32-45 @ 945 MHz
JEDEC #5 14.0-14-14-34-48 @ 1018 MHz
JEDEC #6 15.0-15-15-36-50 @ 1066 MHz
JEDEC #7 16.0-15-15-36-50 @ 1066 MHz
XMP profile XMP-3200
Specification DDR4-3200
Voltage level 1.350 Volts
Min Cycle time 0.625 ns (1600 MHz)
Max CL 16.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tRAS 23.75 ns
Min tRC 35.00 ns
Min tRRD 2.50 ns
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 16.0-18-18-38-56-n.a @ 1600 MHz (1.350 Volts)
DIMM # 2
SMBus address 0x52
Memory type DDR4
Module format UDIMM
Size 16384 MBytes
EPP no
XMP yes
XMP revision 2.0
AMP no
Max CL 16.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tRAS 23.75 ns
Min tRC 35.00 ns
Min tRRD 2.50 ns
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR4
Module format UDIMM
Size 16384 MBytes
EPP no
XMP yes
XMP revision 2.0
AMP no
Max CL 16.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tRAS 23.75 ns
Min tRC 35.00 ns
Min tRRD 2.50 ns
DIMM # 2
SMBus address 0x52
Memory type DDR4
Module format UDIMM
Size 16384 MBytes
EPP no
XMP yes
XMP revision 2.0
AMP no
Max CL 16.0
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tRAS 23.75 ns
Min tRC 35.00 ns
Min tRRD 2.50 ns
plutomate
MAJOR GENERAL
I'm guessing it has something to do with the stick, the information in SPD is default = 2666Mhz rather than 2933Mhz plus this chipset has no memory overclock feature.
But really there is no much difference between 2933 and 2666Mhz, and if you really care about overclocking, better just get Z chipset for better compatibility.
Pro
Agreed, i'd just use DDR4-2666. You have a very entry-level board model, you can't expect much of it. If you want a board with all the options, you're gonna have to spend double that amount at least.
You can try a BIOS update, maybe this will improve something.
Update how-to:
1) Get the latest BIOS. It's always the topmost one when you click on "BIOS" on the MSI support page for the mainboard. https://www.msi.com/Motherboard/H410M-A-PRO/support#down-bios
RemusM
LIEUTENANT COLONEL
Hi All,
  • Intel® Core™ i7/ i9
    • Supports up to DDR4 2933 MHz
  • Intel® Core™ i5 and below
    • Supports up to DDR4 2666 MHz
  • And because your CPU is Core i5 10400 ...
