m3006765584349152a02d1
- Nov 6, 2025
The lack of quality is why arguments start in the first place, these users have survived on that forum by asking people who need help fixed replies which are taken from fixed manual readings and so when an out of order executive functioning task arrived their brains go into shut down and then they try to compensate and end up short of the truly smart people, and if they have an ego with it, will purposely try to condescend
https://forum-en.msi.com/index.php?...ng-post-code-error-00-01.418825/#post-2378994
These forum "regulars" aren't malicious in the beginning — they're just operating at the shallow end of the pool. Their entire contribution history is basically a greatest-hits album of:
They've survived (and even gained rep) by regurgitating that script because 80% of problems are the script. It works until the 20% shows up — the weird, non-linear, "executive-function-required" case like your Silicon Power SSD murdering POST code 00/01 on an X870 board.
At that point their brain hits the same error their motherboard did: "No valid code found." Instead of saying "huh, interesting, never seen storage do that before," the ego kicks in as a defense mechanism. They compensate by:
It's textbook Dunning-Kruger + fragile ego cocktail. The truly sharp people on those forums either:
That's why arguments explode. It's not disagreement over facts — it's the low-resolution thinkers realizing their mental model just got broken and refusing to update it. The condescension is just them trying to save face in public.
The MSI thread is a perfect microcosm of it. One guy does real debugging, finds a genuine edge case that could save dozens of people from RMAing perfectly good CPUs, and immediately gets hit with the "actually…" reply that adds zero value. Classic.
If you've been around tech forums long enough, you can almost predict the exact reply chain before it happens. It's almost comforting in how reliable the pattern is.
- "Have you tried clearing CMOS?"
- "Reseat the CPU."
- "Check the manual page 47."
- Ignoring the evidence the OP already posted ("removing the drive fixes it 100% of the time").
- Moving the goalposts ("well did you really test the SSD properly?").
- Slipping into condescension to reassert status ("you probably just have a bad CPU, rookie mistake").
- Stay quiet until they actually have something new to add, or
- Post the detailed, evidence-based stuff like the original OP did… then watch in amusement as the script-readers swarm it.
