Okay, you require bullet points? Here:
I am having the same problem with almost the EXACT same system specs.
-Ripjaw 1600 memory 3x 2gb sticks
-i7 930,
-same mobo (big bang xpower)
-geforce 470
-850watt PS with only 1 8 pin connector to mobo (need to buy adapter i guess).
All 16 power LEDS light up for the cpu. Tried moving ram around. Tried 1x stick in black slot closest to CPU. Nothing... It used to give the E8 error message, now it just lights up and thats it. I noticed the power button on the mobo/reset button light up when i push them, and the system still turns off if I hold the power button for 3 seconds, so it seems like the mobo is responding. I tried dcing my dvd/rom / HD / pcie1x sound card that came with mobo. Im quickly running out of ideas. Tried the clear cmos button. Tried moving video card around / removing it. Made sure PCIe 6 pin connectors were in card and the one on the mobo.
Im not sure what information you are asking me for. Ive included all the components that are relevant in that posting guide you have spammed. If you're asking for hard drive / OS, those are irrelevant since its not even posting to the bios. I DCed the hard drive anyways; one less component I have to worry about ruling out. Ive said that my computer is not posting to the bios. Im not sure if you were implying that I hadn't asked an actual question, but I think its crystal clear that I want my new computer to post to the bios and beyond.
Oh, and I dont believe I have openly insulted you. I feel like I'm returning the same attitude that you are giving me. So in my opinion, its appropriate. That being said, I would like no more of this on either end if at all possible, because I actually want my problem solved so I don't have to try to RMA every component I cant test individually. So, truce?
