Kha-OverclockDotNet
- Nov 17, 2020
What mainboards you guys have, can you please tell ?
Aorus B550 Elite rev 1What mainboards you guys have, can you please tell ?
Hmm, after trying out these exact settings I haven't ran into any issues so far. ( 1 1/2 days of testing ) Will reply in a few days if it's just luck or if these settings really did something.For those who can't wait there is a workaround.
You have to go the the Device Properties -> Advanced and disable:
Advanced EEE
ARP Offload
Energy-Efficient Ethernet
Gigabit-Lite
Green Ethernet
Interrupt Moderation
IPv5 Checksum Offload
Large Send Offload v2 (IPv4)
Large Send Offload v2 (IPv6)
NS Offload
Power Saving Mode
TCP Checksum Offload (IPv4)
TCP Checksum Offload (IPv6)
UDP Checksum Offload (IPv4)
UDP Checksum Offload (IPv6)
And of course in Power Management disable Allow the computer to turn off this device.
P.S This issue dragging more than 6 months, thousands of people having same issue and no word/fix from Realtek, shame!
B550 Aorus MasterWhat mainboards you guys have, can you please tell ?
With these settings I can run u/q/bitTorrent 24/7, downloading, uploading with 0 net drops. This must be a driver level issue.Hmm, after trying out these exact settings I haven't ran into any issues so far. ( 1 1/2 days of testing ) Will reply in a few days if it's just luck or if these settings really did something.
Not quite. Running plain, without offloads, buffers, flow control and interrupt moderation shows that the controller is not functioning how it should.With these settings I can run u/q/bitTorrent 24/7, downloading, uploading with 0 net drops. This must be a driver level issue.
Same here. Some issues I was having are "gone" at the moment, testing since yesterday. But my Intel PCIe card arrives in 2 days, so don't have long left to use this onboard BS.Hmm, after trying out these exact settings I haven't ran into any issues so far. ( 1 1/2 days of testing ) Will reply in a few days if it's just luck or if these settings really did something.
Obivously a dedicated Ethernet card can prove to be a viable solution, but leaving things like this is definitely not a solution either.But my Intel PCIe card arrives in 2 days, so don't have long left to use this onboard BS.
Agreed. We can try to send some copy pasta message to Realtek support. A collective letter if you will.Obivously a dedicated Ethernet card can prove to be a viable solution, but leaving things like this is definitely not a solution either.
Good luck with that. MSI has one of the absolute best boards and video cards year after year.This will be my last MSI Board.
I have the same issue with MSI Motherboard. But I'm lucky to have a friend in Realtek. He told me they took it very seriously (many people are f**king them, haha), their RD engineer has been concentrated on setting up the test environment, and analysing it.I think the best thing is to maintain the discussion with the producers, like MSI, Gigabyte and so on, they are the only ones who can put real pressure on Realtek, since it's their partner after all.
No wonder, the extreme greed of motherboard manufacturers made them use this craptastic cheap NIC instead of Intel on almost every product.I have the same problem on my x570 Unify with latest beta Bios A86 and also with A85.
