piatt.15a602e2
- Mar 25, 2025
I see this is a very common issue going through the threads and google search's. Any insight is greatly appreciated.
I have built plenty of intel based rigs with no issues, this is my 1st AMD build. PC is full water cooled so re-setting the CPU and checking for bent pins will be a last resort if needed.
PC will boot with only one ram stick in B1 slot. Will not work in any other slot and will not work with a second ram stick inserted.
Edit: Pc will post with ram sticks in A1&B1.
I've tried clearing cmos and waiting more than 5-10 minutes for the learning portion with no success.
I've check all power cables and ensured they are fully connected.
Updated bios to most recent E7E09AMS.1E2
Specs: B650M Project Zero
Lian Li Edge 1300 PSU
AMD AM5 9800X3D
Asus Pro Art 4080 Super GPU
Ram DDR5 32GB 16GBx2 6000mhz (AMD EXPO)
I originally purchased the Dominator Titanium 64GB 6000 4x16gb ( Not EXPO specific) Would like to use this option if I can get it figured out.
AMD AM5 9800X3D
