RED LIGHT BLINKING
Hi, I was wondering if anyone had a similar issue as I do?
I purchased a MSI AEGIS SE PC about 2 months ago 😢and I was wondering if anyone had an issue with this red light blinking near the power
button? I believe its next to a cylinder looking pic. I did notice it starts to get hot when its been running for an hour??
Thank your for any response in advance!! :-)
darkhawk
See : >>Posting Guide<<
Please provide more specific information. "Running hot" doesn't tell me anything. Hot to you could mean 60C, where as hot to me really means 100C. There's a big difference there, and unfortunately, one is OK and one is not.
So please be much more specific in your examples and information, otherwise we really aren't going to be able to do much here to help.
Let me fill out that posting guide form for you. right now I checked the GPU temp Its running at 80C its been on for an hour now. Attached is the blinking light that I mentioned.
As for the temperature issue, I did have help from someone locally. They had adjusted setting on the computer and had me monitor for the next few days for changes.
I was suggested to add more fans to my pc to help with the cooling. Thank you both for your help!​
