Review of MSI PRO Z690-A WIFI DDR4
Status
Not open for further replies.
honchinkan12a102a9
Have recently upgrade my desktop PC to the new intel alder lake, which also means it was time to change the motherboard too. I went with the budget and good option recommended by many others, the (MSI PRO Z690-A WIFI DDR4). As it is more of a budget board, there is no RGB component to it unlike the others. The motherboard works great with my intel i7-12700kf, but do note that you will need to install the WIFI driver from the MSI site if you plan to use the WIFI function of the MB. It comes with many USB ports and even with one USB-C port if you need it. Overall it is a great choice if you are planning to get a budget board with many features!
Status
