RGB Converter
armywooah1
I'm trying to hook up my new MSI CPU MAG Coreliquid 240R to my 2019 MSI B360M Bazooka. The MAG Coreliquid 240R has 3pin connector, and my B360M Bazooka has 4pin connector. I thought MSI products were suppose to be compatible. My MoBo is only 3yrs old. Does anyone know of a converter that will work? Regards
Alan J T
three pin and Four pin Fan connectors use the same Motherboard header the plug is keyed so you can not get it wrong
Ye will definitely need a HUB for the RGB
MAke sure you get one for a know manufacture as some of the cheaper ones can cause problems due to shoddy manufacturing and parts used.
I believe one like this will make use of your USB 2.0 port to control the RGB
