- Nov 20, 2012
MSI Pin Layout
[attachthumb=1]
NOTE : Addressable RGB LED's allow LED's to be controlled either in pairs or individually, while non-addressable RGB LED's (JRGB1/JRGB2 headers) require all LED's to be the same color.
On those board, once you install Mystic Light 2, it will have two bubble referring to JCORSAIR-LED STRIPE & JCORSAIR-FAN.
The supported device would be CORSAIR LIGHTING NODE RPO & CORSAIR HD120 RGB FAN.
[attachthumb=2]
This is how you connect the device.
The LED stripe should be good to go but fan is a little bit trickier. You MUST connect the RGB fan through a HUB and follow the order of the slot on HUB . Ex. From slot 1 to 6 instead of starting from slot 3 first.
Once it?s been connected properly, you don?t need corsair software to control the LED.
[attachthumb=1]
[attachthumb=2]
