RGB lighting on MSI Raider 16 Max HX B2WI
gamin15b202e5
Today I received my MSI Raider 16 Max HX B2WI.
However, I am unable to get the RGB to work.
There should be something like:
  • SteelSeries GG/Engine → per-key keyboard lighting
  • MSI Center (Mystic Light) → chassis/underglow/logo RGB
However, I cannot find Mystic Light in MSI Center [not in Features, Settings etc]
How do I get this RGB lighting to work?
Mystic light should be able to download from the Feature sets in MSI Center. Try to find the icon with four blocks on MSI Center's page, which is on the top right of the window.
Connect to the internet, and you should find the features to download.
I don't have Mystic Light listed in these Feature blocks.
These are the 'only' tiles I have.
I alse uninstalled MSI Center with the official uninstaller, and reinstalled from the Microsft Store.
After a BIOS update from April 17, and a couple of reboots later [for whatever reason it didn't changed the first time] the RGB lighting on the front strip and keyboard is working :D
However, Mystic Light is -still- not showing up in MSI Center.
How can I control the RGB coloring, as well as keyboard?
PS Mystic Light also has issues updating via Microsoft Software (within its own version of 2.0.68.0).
MSI Center 2.0.68.0 is currently already installed on my machine.
I have MSI Titan 18HX, MSI Center isn't even working. Stuck here from eternity
Someone told to clean uninstall and then again install te previous verision. Tried that 5 times but still same issue.
Someone also told that clean uninstall and then install the latest version directly from the store, I tried that but still no success.
I only want MSI Center because I want to use battery charging capping. Otherwise no use of MSI Center
In my case it, at least, helped to update the BIOS. Have you done that?
I also read somewhere that the SDK to MSI Companion/Mystic hasn't been fully updated yet because this notebook has just released.
Hopefully, a fix/update will be out soon...?!
