spamwastegroun151802ce
- Oct 17, 2022
I’ve been using a MAG CORELIQUID 360R on a x470 Gaming motherboard and even after adding 3 extra fans to the radiator to give a push pull configuration and putting the fans at 75% speed I’m still getting a ludicrous 84 degrees under load on the CPU, and a more respectable 40 at idle.
I have 2 140mm exhaust fans on the top of the case, 1 inlet at the back blowing cold air on the mosfet area, and 2 fans pushing cold air in from the bottom onto the graphics card and aiding the reduction of a slightly positive pressure environment in the case.
I’ve been watercooling PCs since 2002 and have never seen such a ridiculous temperature delta. I’m only cooling a Ryzen 3600 at stock clocks and it just seems crazy that there should be such a shift.
The pump did start making some noise around a month ago during boot, like it was producing cavitation but after I reseated the cpu block that has stopped. I’m now wondering it was an impeller issue and I’ve lost a blade or something within the system.
Can anyone shed any light on a method of fixing this, or do I just ditch the thing and buy a Coolermaster 360R instead. I’m really not impressed with the cooling solutions from MSI at the moment, and I’m concerned about that delta during gaming so much I have CPUZ open constantly on another monitor…
Any ideas from the collective greatly appreciated.
