tomuliuka15c002e5
- Jan 28, 2026
Hi everyone, I’m running into a persistent PCIe link speed negotiation issue with my current setup and wanted to see if anyone else is experiencing something similar or has found a workaround.
My Hardware:
Motherboard: MSI PRO X870-P WIFI
CPU: AMD Ryzen 7800X3D
GPU: NVIDIA GeForce RTX 5070 Ti
BIOS Version: Agesa 1.3.0.1b Patch A (7E47v1A92)
A The Issue: On cold boots, the PCIe link speed between the motherboard and the RTX 5070 Ti inconsistently negotiates. Sometimes it hits PCIe 5.0 as intended, but frequently it drops down to PCIe 4.0 or even PCIe 3.0. Interestingly, the system remains stable and game performance is fine, but it refuses to consistently lock at PCIe 5.0.
What I've tried / checked:
- Above 4G Decoding and Resizable BAR are enabled in BIOS.
- EXPO is enabled and stable.
- Disabled the iGPU (which completely fixed initial cold-boot stutters/lag, a known quirk, but did not fix the PCIe speed fluctuation).
- Forced settings are currently on Auto, as trying to force Gen 5 manually results in a black screen/no post since the link negotiation fails at startup.
The GPU is definitely seated properly since it does successfully hit PCIe 5.0 sometimes—if it were physically misaligned or poorly fitted, it wouldn't be able to negotiate that speed at all. As for setting it manually to Gen 4, I'm a bit hesitant because of the cold-boot instability. If the system/microcode still struggles during the initial training phase, forcing Gen 4 might just trigger a black screen or no-post if it drops down even further during boot. Right now, leaving it on Auto lets it boot up stably (usually landing on Gen 3).
It seems like an early platform AGESA / microcode issue regarding PCIe training with the new 50-series cards on X870. Has anyone found a BIOS setting tweak or a stable workaround for this, or are we just waiting for a newer AGESA update (like 1.3.0.2 or later) from MSI? Thanks in advance for any insights!
P.S. I posted this problem on Reddit and there are many users with the same problem, not only me.
Post:
My Hardware:
Post:
