Running 2 Nvidia Quadro FX 4600 GPUs in SLi ?
notismanara161902f0
Hello everyone and good afternoon.
I would like to know if I can run 2 Quadro FX 4600 GPUs in SLi in my MSI P6N SLI Platinum. While I have checked that this motherboard is SLi compatible , I can't find any information about it being Quadro SLi compatible. I just want to check if I can do this , since it's for a college presentation.
Thanks everyone for your precious time.
That ancient motherboard is SLI compatible.
See: https://www.msi.com/Motherboard/P6N_SLI_Platinum/Specification
Two PCI Express x16 slots (supports PCI Express Bus specification v1.0a compliant)
- these two slots can support SLI technology with PCIE x8 mode.
- the second PCI Express x 16 slot (PCI_E4) is a special design that supports PCI Express x 8 mode only.
- the second PCI Express x 16 slot (PCI_E4) only supports to install graphics card in SLI mode.
But it's not Quadro SLI compatible.
See: https://www.nvidia.com/en-eu/products/workstations/quadro/sli-ready-motherboards/
Thank you for your reply.
I have tested the geforce game ready drivers with the quadro FX 4600 and it gets recognised. Could it be possible to run them in sli using the Game ready drivers instead of the quadro drivers ?
Thank you
