Screen saver not working because of GM51 mouse
MrXxX
When I use the GM51 wireless mouse with the type-c cable attached, it does not enter the screen saver and the monitor screen turns back on. This problem does not occur when the type-c cable is not plugged in. The source of the problem is in the GM51 section on Msi Center/Gaming Mode. When you go to this section ''Msi Center/Gaming Mode/GM51/POWER'', "LED sleep mode" tick appears when the type c cable is not attached. I think the problem from this reason. How can I solve this problem?
FYI: The issue is duplicated and MSI is working on a solution.
In meantime as temporary workaround you can disable LED Power Saving Mode in Mystic Light Settings.
