Search engine, internet issues, computer stops working, oc genie failed... z97g5
Roirraw
CORPORAL
Ok so I have fully reinstalled OS. I had some problems, because my PC couldn't find CD/DVD connected by usb, but connecting it directly to motherboard solved this thing. I deleted all disk partitions and divided them again. I installed OS without problems. After that I installed MSI drivers from CD, and downloaded from internet Live Update as well as google chrome and kaspersky pure 3.0
This time I had no problem with installing kaspersky. Before reinstalling OS I couldn't install Kaspersky Pure 3.0. Is it possible that everything was brought by infected PC? Like I had no problems with freezing of my browser after adblock crashed (I guess) and I had a lot of adware ads. Is it possible, that Adblock was blocking "adwares" and thats why sometimes my browser freezed? Or maybe my whole PC was infected since I could not install Kaspersky Pure?
What should I do now? Nothing? Test and see what happens? I would really like to set my BIOS settings properly.
Roirraw
CORPORAL
Very weird thing happend. So I installed only two drivers from CD - chipset for intel and Killer Network Manager. My PC automatically connected to network and I have downloaded Live Update from msi site. I started updating Kaspersky Pure 3.0 and Intel Chipset as well from Live Update at the same time. So my PC has rebooted after installing new drivers for intel chipset. Afterwards I noticed that I can't connect to the Internet. There was no Killer Network Manager as well, and my Kaspersky tried to update databases, but it indicated that he has already downloaded 2% of update.
So I took my CD again, and installed Network Killer Manager. After that I am connected to the Internet again. One more interesting thing. After I installed Killer Manager, it's shortcut was at the bottom on my destop, but after some seconds It automatically went to it's previous place - between Kaspersky shortcut and Live Update shortcut...
I don't want to install wrong drivers so tell me what should I install for my graphic card. I have installed drivers from nividia website, but here are drivers from asus - http://www.asus.com/pl/Graphics_Cards/GTX770DC2OC2GD5/HelpDesk_Download/ this is my graphic card, should I install all drivers which are there?
(I know that the website is in polish, but if you pick from "Prosz? Wybra? System operacyjny" win 8.1 64bit than u have drivers with english descriptions. Or maybe I should download them from english asus website?)
badboy2k
you have the driver from Nvidia so that's probably the newest available for your card as its from the GPU maker!
as for the rest like Utilities and BIOS it depends:
if you want the 2 utilities one is for game streaming and the other is a Overclocking utility its up to you if you want them! and as for the BIOS if i was you for that if you want to update the Firmware the card uses i would contact ASUS and ask them for it just encase the version available is not for your exact card as in a production run the memory can change mid run and have different voltages and timings so its better to ask for that so you do not brick your card!
Roirraw
CORPORAL
Thanks guys for your help, from 3 forums where I asked for help, this one is the best.
Just let me know if I should change BIOS settings, or leave it until something goes wrong.
TZBC
CAPTAIN
Try disable Kaspersky Pure 3.0 or uninstall it ?
