wolstan-dixi156702d7
- Mar 19, 2022
My PC has a 2014 A55M-E35 motherboard. This has a serial port connector JCOM1. Serial ports being ancient technology I have never used it. Now, after eight years, I need it to connect to a serial digitising pad. I therefore bought a serial/parallel DB9/DB25 back panel interface and plugged the DB9 into JCOM1.
It is apparently dead - with hardware handshaking disabled it won't communicate via a null modem cable with the digitising pad, and a simple loopback of connecting pins 2 & 3 with a terminal emulator produces nothing.
Device manager shows a COM1 and that it 'is working correctly'.
As it has never been used for eight years from new it seems unlikely it never worked - is there some trick to turning it on?
Any expertise gratefully received - thanks.
