Jesus this board has been a wild ride today.
#1. Woke up to a failed memtest86+. Following the memtest86+ errors that I woke up to this morning, I decided to just reset the CMOS. And this is with whatever the defaults were after a BIOS upgrade that night from an October bios version I believe to the newest bios as of December or "January".
#2. Did a quick CMOS reset. Enabled EXPO1. This time I disabled Memory Context Restore, thinking that might be the issue. Boot time went up to ~50 seconds doing this.
#3. Ran another memtest86+ test. Passed. Also the entire system just felt more stable.
#4. Decided to finally install Windows 11. No workable ethernet drivers or wifi. Ok, annoying but no big deal. Or was it?
#5. Realtek ethernet drivers installed, no luck. That's when I noticed my port had no light as mentioned in the previous post.
#6. Uninstalled and reinstalled ethernet drivers, no luck. Windows claims device is working fine. Full driver suite from msi is installed using msi center.
#7. I locate
this post & where others had the same issue with LAN being dead on this board and suggestions for fixes.
#8. I was able to get the LAN jack to wake up it by turning off my PSU, unplugging the power cord as well, and performing CMOS reset that way (about 10 seconds on the button).
#9. This yet-another-cmos reset this time caused the system to not boot up getting all the up to the memory init and error code "EC" was shown. EC in the manual: "Reserved for future AMI error codes." Fantastic!
#10. Failing to get the computer to boot, I did another CMOS reset repeating what I did in 8, same error code while booting.
#11. I pulled a stick of my F5-6000J3040G32GX2-TZ5N 32GB out. Viola, it booted. Applied EXPO1 preset to the 32gb memory. Did not change memory context settings or anything else this time, those are set to all defaults of whatever the current BIOS tells it to.
#12. Ethernet fixed! Just like that, the CMOS clearance reactivated my ethernet jack. It is DEFINITELY not because of anything I did with drivers. Driver installs were a dead end. Why did that cmos clearance work? Who the hell knows, if MSI could explain it that'd be great.
#13. On the single 32gb stick I took this opportunity to run HCI memory tester in windows for a little over an hour. No errors found.
#14. I reinstalled the second 32gb stick back in. BIOS detected the change, jumped in, enabled EXPO1 presets again. Again this time I did not change memory context settings. Boot times are 15-20 seconds-ish with it on 'Auto' so it must mean it's actually on.
#15. I have had no BSODs throughout my testing and use of windows this evening, the ethernet jack is stable, unplug and plugged in things to every USB port, I have not been able to trigger any instability. I ran HCI memory test for about 30 minutes and didn't find anything. But I am now hammering it overnight with HCI memory test to see if it can find anything on either of my two modules.
The LAN issue with this board I had just doesn't inspire confidence. And -- it's still preliminary, but I feel like the last CMOS clearance with the PSU off did *something* to smack this board back into working the way it should. I'm beyond disappointed at how buggy this experience has been and it's hard to trust it right now.
