Short battery life GP62MVR leopard Pro
lucianomattar
Dear,
I bought the GP62mVR Leopard PRO 2 weeks ago. The battery life is very short, less than 2 hours, in usual tasks like internet and Office package. I would ask you guys suggestions about how to solve this problem. I updated the bios, but the problem continues.
Sincerely
2 hours battery life with certain usage should be reasonable score.
If you disable the network connection, adjust power option/plan and don?t use the Nvidia GPU.
The battery life could extend to 3 or 4 hours easily.
Thank you.
Please, can you tell some kind of battery life test for I see if battery have problems? think that MSI should have some parameters to test the quality of the battery of notebooks.
Best
