- Apr 16, 2014
Here is a short review from a standard user in PC world
Finally i decided to jump to Intel 12th gen. Choosing the I7 12700K and pair it up with this motherboard.
From the looks of it yeah it looks plain. Personally i don't need it to be too flashy
https://www.msi.com/Motherboard/MAG-Z690-TO...4/Specification for specs can just go the link.
Some quick pros why i choose
-DDR4 (so can just use the ram that i already owned Kingston Hyperx fury rgb 8x2 2666Mhz. xmp set run flawlessly)
-Decent amount of PWM fan and argb connector. So can easily manage
-Debug LED simple yet very useful
-4 slot of m.2. Will be really useful for next clean storage expand. Currently using 1 slot only.
BIOS menu for MSI is soo easy because of the placement and familiarity. Decided to down volt cpu because its running on full clock with high temp.
That all for now.
That all for now.
