shutdown and overclocking
viking73
PRIVATE FIRST CLASS
new problem...maybe. today my system shutdown itself. I restart it and it would start then stop, start again and then stop. I thought it might be something with the power supply so i disconnected one of my 2 gtx 260 video cards do reduce the power drain. It started and gave me a  message shown here.
What is not shown in the picture is "133x20=2660" in the upper right corner. I have never touched anything that has to do with overclocking and no one else uses this system. The cmos was set to optimized defaults. Since it set itself to a default setting, I plugged the second GTX 260 back in and things are working again.
1.) does the i7 quad core overclock itself for some reason?
2.) I was plugged into an APC 800 backup UPS and I have a Corsair HX1000 power supply. Is this a problem?
NovJoe
GENERAL OF THE ARMY
Check in your Event Viewer under system log and see what are the errors or warnings which happened prior to the shutdown.
NovJoe
GENERAL OF THE ARMY
I suggest that you set the BIOS back to factory defaults and try booting with barebone conditions and see how it goes.
Smoke
I get this same situation.. except the event viewer doesnt state anything.
The system is not bluescreening.. it just hardware powers down and reboots.
I get the same message as the original poster as well, it is very annoying as it often happens in the middle of doing something.
I wonder if it could be thermal related to the high IOH temps on the board (often 80-85C, but not sure what happens to them in the middle of playing a game)? Is there any way to log the temperatures to a file so I can check what they were at the time of the crash?
I get this issue whether I change the default bios settings or not. Ive got a 920 on my eclipse board, my CPU temps are below 30C under load. System temp is about 27C.
What can I do?
Aaron
GENERAL
That's way too high, even for 100% load.  Reinstall the heatsink.
Smoke
It is? I found another thread on this forum where it was mentioned that intel and msi said the IOH runs hot and to expect temps up to 100C. How do I go about changing the manufacturers heatsink on a board? Ive never done that before and cant find any procedural help thru google...
Ive been able to replicate the issue by running ram up to high usage. When I get above 98% ram allocation, I spontaneously reboot. So It could be a ram issue as well. Of would that be something possible IOH related as well?
NovJoe
GENERAL OF THE ARMY
smoke,
Can you list out your full system spec and PSU spec?
In future, it is better for you to start a new thread so it will not be confusing for TS when he/she comes back and find the thread being hijacked.
Smoke
Apologies. Just the symptoms sounded identical. Ive started a new thread.
NovJoe
GENERAL OF THE ARMY
Appreciate the effort, smoke.
Thanks.
