Shutdown issue
  • Thread starter Thread starter waxmatch
  • Start date Start date
W
waxmatch
Guest
I purchased the KT3 Ultra Mother board yesterday and mounted it in my case, everything was fine. Loaded Windows XP & all the drivers with out an issue. Restarted every time XP told me I needed to. The problem only manifested when I clicked on shut down my PC. Then it shut down and immediately attempted to reboot but knocking out the AGP and beeping continually. I reset the CMOS and restarted, again without a problem until I asked it to shut down and the same problem occurred. After going through the reset procedure again I thought I would attempt to hibernate instead of shut down, again, no sooner had it turned off it powered up and knocked out the AGP port.
Rig
Creative Geforce4 TI4400
512 DDR
60GB HDD
KT3 Ultra
iiyama 451 19"
Lian li PC60 case
PSU 540W (so it is not down to lack of power)
Hi there,
Reset the CMos again, but this time, don't change any setting.....
Now try again.....
If it beeps again at the reboot, you might need to try other memory...
Hello, do you have any PCI devices such as PCI modem, PCI network card etc? It could be one of those PCI items did not shutdown properly and triggered wake-up signal by itself after the shutdown sequence.
No sorry I should have made that clear, I did disable all wake up events because I had a similar thought pattern. However, in answer to your question, no I hadn't put the network card in at that point. Bas I will try your suggestion tonight and either call you a god tomorrow or be looking for further advice from you all. I have a few other possible solutions but will try them out first and give you a further update tomorrow.
Thanks for the advice guys..
Problem solved!! 8)
After changing the memory, rebooting, and listening to the now ritual 3 beeps I was beginning to wonder if perhaps it was the motherboard at fault or even worse me 8o . As a last result I swapped out my 540W PSU for an old 240W one I had lying around used for testing motherboards ect. Success, it shuts down without fault?. Needless to say I am one happy person right now. :D
Let this be a lesson to us all... the power supply unit can be the root of all evil!! :evil:
