Signal out of range...
T
trinkulus
Guest
I'm using a MSI Geforce 2(pro I think, can't remember specifically). A CTX monitor and I just built a new computer with an MSI kt333 board and amd processor. My video issue is I have the lines that appear horizontally across the screen wherever there is a dark bar. For example, when posting a thread, this area where the main text is going it's darker to the left and right of the box. I had this issue in my old Gateway computer with this video card. When I replaced it with an older tnt 2 card I still have the same lines. I've also switched out monitors to see if that was the problem. Since then I've also wiped my hard drive and reinstalled windows 98se and the video drivers fresh. And if this wasn't bad enough, now I'm getting a "signal out of range" message on my monitor so I can't even see anything. I've been trying for months now to fix this and no one seems to be able to help.
trinkulus,
Signal out of Range is the refresh rate set too high. Try going into windows in Safe Mode and readjust your refresh rate.
Good Luck,
Richard
