Smart Priority causing flickering monitor
I have to say, the new new MSI Center is a huge improvment over the old dragon center, that sometimes worked, sometimes didn't. However, there is something in the new Smart Priority thats causeing monitor flickering as the mouse moves in pretty much all applications... It is horrendously noticeable in photoshop. Even switching between two psd files causes this issue, the mouse movements cause this issue. After a little research i found it may have something to do with g-sync and your refresh rate. Also, as a side note, the Advanced Update feature to update the bios STILL doesn't work. It never has, so why do you continue to bundle stuff that just doesnt work? Look, I like MSI products, but your hardware is only as good as the software interface us humans use to interact with it.
