SOLUTION!!TPM attestation not supportedB650 GAMING PLUS WIFI B850 TOMAHAWK MAX WIFI SOLUTION!!!!!!!!
artemlol131281029f
If anyone is experiencing the same TPM attestation not supported problem, here is what finally helped me.
First of all, I tried all the usual troubleshooting steps:
• Updated the BIOS to different available versions.
• Changed different TPM / fTPM settings in the BIOS.
• Tried clearing/resetting the TPM.
• Reinstalled Windows.
• Tried different Windows configurations.
• Checked Secure Boot settings.
• Checked the TPM status in Windows.
• Updated the motherboard/chipset-related drivers.
• Tried different BIOS configurations.
But the most important thing I did was replace the motherboard.
I replaced my B650 motherboard with an MSI B850 Tomahawk MAX WiFi.
The TPM attestation not supported problem remained exactly the same after replacing the motherboard.
The final test
Eventually, I replaced my Ryzen 7 7800X3D with a Ryzen 7 9800X3D.
After changing the CPU, the TPM attestation not supported problem was completely gone.
TPM attestation started working normally, Secure Boot was working correctly, and Faceit launched without the previous error.
So in my case, the problem was not the motherboard. I had already replaced the B650 motherboard with an MSI B850 Tomahawk MAX WiFi, and the TPM attestation not supported problem remained exactly the same.
The component that ultimately solved the problem was the CPU.
Replacing the Ryzen 7 7800X3D with the Ryzen 7 9800X3D completely fixed the TPM attestation not supported problem.
So if you have TPM attestation not supported and have already ruled out the motherboard, BIOS and Windows, don’t overlook the CPU itself.
In my case, replacing the CPU was what finally fixed TPM attestation not supported.
That's not a very good solution, to replace the CPU. For every problem, should we just start replying now, "Just buy a new one, problem solved"?
Such problems can usually be solved in some kind of way that causes no costs, even if that way is not immediately known.
Yep, it's called refunding the game and raging at Activision for causing the mess- a mess that is only going to get worse after the next series of game updates to the anti-cheat when it starts to target your input devices just because you can remap the buttons and other wonderful things they have decided are cheats, like stealth hearing headphones. You will have to disable the headphone software for it to work. Just having certain software and apps installed on your PC can cause it to be flagged for cheating.
If you switch back to the 7800X3D CPU, does the Attestation error appear again?
If you were able to play the game in the past and suddenly encountered Attestation error or being blocked from specific game mode after game update, the issue is probably related to the game itself.
