Solutions to majority of problems related to Restore/ Recovery / MSI F3 factory Reset
Bsl K
Hello again man this time I'm really confused the link that you gave me i downloaded it and did the steps carefully and right and I was using 32 gb usb too so I tried to boot with usb and it showed the RECOVERYDVD Manager for a while then restarted and booted to windows
Did you copy all the install.wim files to RECOVERY_DVD folder? There should be 5 install.wim files.
Find SKUNAME.TXT inside RECOVERY_DVD folder, change the model name from "Prestige 15 A10SC" to yours and try again.
If it does not work then i will give you command to manually create partition.
Ok I'll try and yes I did the steps right i copied them to recovery dvd
Nah man not working
Bsl K
Nah man not working
ok do this then, make win 11/win 10 bootable usb. (you can later shrink or extend the size of your partitions. i guess you have 500GB SSD in gpt style.)
Boot with windows bootable usb, on the first screen press shift+f10
then type these command one by one
diskpart
select disk 0
clean
convert gpt
create partition efi size=300
format quick fs=fat32 label="System"
assign letter="S"
create partition msr size=128
create partition primary size= 256000
format quick fs=ntfs label="Windows"
assign letter="W"
create partition primary size=900
format quick fs=ntfs label="WinRE tools"
set id="de94bba4-06d1-4d40-a16a-bfd50179d6ac"
gpt attributes=0x8000000000000001
assign letter="T"
format quick fs=ntfs label="DATA"
assign letter="Y"
Select Partition 5
Shrink Desired=15656
format quick fs=ntfs label="BIOS_RVY"
assign letter="R"
REM RECOVERY_IMAGE_SIZE_V = 15656
exit
exit
Bsl K
Nah man not working
after that continue installing windows 10 or 11. later after installing all the drivers , capture system image as in tutorial. and you will also have to replace the winre.wim file that i will teach you later. do it first and we will continue later.
And the reason why I had problem with usb recovery because my system product name is messed up it only show numbers but it was supposed to show the name not numbers
And manufacturer name is messed up too and when I try to change product name from registry it restores back to numbers
Hey so uh I'm finishing the win 10 downloading can you keep an eye in there so you can answer fast
I have been finished win 10 installing what do I need to do now
Bsl K
Now install all the basic drivers for your laptop from msi website.
You can pm me. We don't have to continue on comments. Pm me and i will tell you what to do next..
Also I'm finishing downloading the basic drivers but why should I download basics they are kinda old
So hello again man your tutorial is really perfect and after i understanded i used the factory reset and it works but the problem is about language and the edition of the windows is corecountryspecific and i need product key but i don't have it is there any other way to change language and aren't my bios supposed to activate it automatic
Nevermind forget about it i fixed and man your a beast thank you for helping me to get my recovery back i really appreciate it
Also btw i have one more question is it possible to make your recovery files in english language? cause I don't know chinese language and even with activating the windows and changing the language still doesn't change some things like some of things in my laptop is chinese language
Bsl K
You have to install windows in english and then make backup as shown in tutorial and then replace the recovery image with your custom made recovery files.
Uhm I'm really confused in there like installing windows with usb? and I'm confused with making custom recovery files too can you like show tutorial or explain it
yuzucual15cf02ef
It may be irrelevant to the topic, but I also have a problem with the msi laptop. In fact, this problem caused me to lose the recovery section. My Problem Is This. I'm using a voice analysis program called Platinum Notes. A program that makes the sound level idael and prevents explosions in the sound. After a while after I start using this program, it closes without error. Thinking that this problem was related to the software, I formatted the computer and unfortunately lost the recovery section. But I still haven't solved the problem. I checked the problem log on the event viewer, but again I couldn't find anything. Turkish English, I have received the records of the problem in english, Polish and turkish. I would like to ask you to please review this recording and share with me what the problem is, possible solution suggestions. My laptop model is Katana GF76-12UC. I took my financial means with difficulty, especially for work, but I can't do my job. I'd appreciate it if you could help. Thank you to everyone who is interested already.
Error Save File: https://ufile.io/dtb5dc0x
Hello there, I might try to help you what I learned from Bsl K but can you send me your disk management first, so I might know what is the problem.
yuzucual15cf02ef
F3 kurtarma işleminizi geri istiyorsanız, biçim sırasında sürücünüzün bölüm boyutunu manuel olarak ayarlamanız gerekir. Ancak bu, sabit diskinizi temizleyecektir. İsterseniz, format sırasında kullanmanız için size komut verebilirim.
En iyi çözüm değil, ancak yapabileceğiniz bir şey, sabit sürücünüzü biçimlendirmek için prestige 15 modelimin kurtarma dosyasını kullanmaktır. daha sonra dizüstü bilgisayarınız için gereken sürücüleri yükleyebilir veya kaldırabilirsiniz.
dosyaları indirmek için BU BAĞLANTIYI kullanın. Talimatları açıkça okuyun.
Dizüstü bilgisayar modelime ait dosyayı bu bağlantıda bulamadım. Katana GF76-12UC dosyalarını benimle paylaşır mısınız?
Kötü İngilizcem için üzgünüm. Çeviri yardımıyla bir mesaj yazıyorum.
