[Solved] about GE60 2pc apache build in mic problem
AOkhew
when i skype with friend ,
i can listen the sound very well , but my friend can recieve mine
hchg
Active member
LIEUTENANT COLONEL
Check the Recording device settings, see if it's been disabled.
If it's not disabled, try reinstall the Reltek Audio driver from msi website.
chc
Active member
MAJOR
Find microphone property and adjust microphone boost to higher level. Try if this help you out.
BlueAlexFPS
MAJOR
I think it's not really the microphone issue, might be the setup of Skype issue.
hchg
Active member
LIEUTENANT COLONEL
Does the microphone work sometime, but sometime don't?
Ctrl+A and Ctrl+S make the microphone enable/disable, and I think it might be the reason.
AOkhew
found it , thanks my friends ~~~
finally found the problem , msi My Support still havent reply my question ...xD
