Check PMsame problem
LED and Display wont work after update. Here is the specs:
LED FW Update(7c70)
currently using RGB Fusion and iCue, they work fine but the MBO led + led strip + display dont work
I hate to sound like a broken record but yes same problem
LED FW Update(7c70)
Check PMMy dynamic dashboard isnt working either, can you please help me?
Sorry this thread is not for ARGB controllers ... it's about Dynamic Dashboard III can't control argb on my x570 meg ace motherboard, it lights up steadily, it went to the service, but no solution was found, it doesn't change what I did, I would appreciate if you help
thank you i write with google translate sometimes it gets confused do you have any idea where i can open the right topicSorry this thread is not for ARGB controllers ... it's about Dynamic Dashboard II
It's a completely unrelated chipset than ARGB
How did u fix it?Please check your PM
Furna
I'm having the same issue please help me with the fix@Luca Furna
Please check PM, I will assist with this issue in there.
Check PMI'm having the same issue please help me with the fix
Please check PMSame here guys, can someone PM me on how to fix? why not post the fix so we don't have to ask?
