Combat Wolf
- Aug 14, 2021
My dashboard is also not working ,but the Numbers are fine. Can someone help?
If you have a Z490 motherboard you can use the tool in your PMMy dashboard is also not working ,but the Numbers are fine. Can someone help?
If you have a Z490 motherboard, check PMI have the same issue, can someone send me the fix?
Is it resolved now? I facing same issue comments are soo much not finding the solution.Hi,
as per the title after I upgraded my MEG Z490 Godlike motherboard's led firmware, I noticed the Dynamic Dashboard II is not powering up at all and do not react to any command in Dragon Center's Mystic Light Dynamic Dashboard II panel. Also the RAM is not available anymore in Dragon Center's Mystic Light.
I still can retrieve the MB LED FW version, so I think the hardware is still working and re-flashing is still possible.
Here my firmware/software versions
BIOS MS-7C70 1.2.0
MB LED FW LED_0F OLED_0D
Dragon Center 2.0.82.0
Mystic Light 1.0.0.92
Is there any method to re-flash/downgrade the motherboard's led firmware?
Any hint is appreciated.
Thanks
Luca Furna
If you have a Z490 motherboard, you can use the tool suggested in PMIs it resolved now? I facing same issue comments are soo much not finding the solution.
Check PMHello Furna I am having the same issue with my MPG Z490 GAMING EDGE WIFI if you could help that would be great!
Check PMI believe I'm also experiencing the same thing on a z490 Godlike. The OLED screen is completely blank (Only the 2 digit temperature/post display works)
Ambient lighting elsewhere on the board works
You're my personal hero. Followed the instructions included with the link in your PM, rebooted and everything is now working properly.Check PM
Hello,Exact same issue with my X570 Godlike. MB Display doesn't show anything or seem to be powered on, yet LED numbers show up. I also have Corsair memory and iCue
