[SOLVED] MEG Z490 Godlike Dynamic Dashboard II not working and Corsair RAM RGB not showing up in Mystic Light after MB LED FW update in Dragon Center
skmac007
I am also struggling with the same problem.
It occurred after installing the latest version of the chipset.
The answer tells me to check the PM, but what is the PM?
Furna
The sky above the port was the color of television
Hello @skmac007
do you have a Z490 motherboard?
A PM is a Private Message ... I think you still have no PM yet ;-)
Again .. Z490 motherboard with Dynamic Dashboard II ?
erolemli12a202b0
Hello everyone, I have the same problem with my Z490 Godlike. I no longer see any hardware in mystic lights and an error message appears. I can't reset the BIOS either and am currently using my 2nd BIOS because the first one has become extremely slow and sometimes doesn't initialize my hardware.
This only happened after an update via the msi center
Can any one help me?
Thanks
Furna
Thanks
I would first resolve the BIOS issue before thinking about Dynamic Dashboard II and/or RGB.
Also from you post it is not clear if you have problems with Dynamic Dashboard or Mystic Light software ... you wrote about an error but you do not specify what error ...
Anyway start resolving the BIOS issue ... did you already tried to re-flash it? Godlike can reflash the BIOS from an USB using the button of the back of the motherboard; pag 67 of the User Manual
erolemli12a202b0
Thanks for the feedback.
The error in msi center (mystic lights) is:
"The mainboard's LED firmware is abnormal. Please get into Support-Live Update and click Advanced to scan and update MB LED FW"
My dynamic dashboard shows nothing only the the two letters for temp. And error code is working.
My B-Bios is still working normal, but I can't use M-flash, they don't start. Only a black screen. After restart it shows me the info for exit m-flash and that is all.
The flashback function over the button on the back can't found any bios on the usb device. Searching over an hour
erolemli12a202b0
I finally managed to do it with the default bios. The dynamic dashboard shows it again. Now only the error message from the mystic lights "The mainboard's LED firmware is abnormal. Please get into Support-Live Update and click Advanced to scan and update MB LED FW". I only see the rgb control of my MSI graphics card. Everything else is not visible.
Furna
Check PM
cbhappy
Hi Furna. I have the same issue. z490 godlike and the dynamic dash II does not come on. In addition my gskill rgb ram can no longer be controlled in mystic light or gskill software. Please help. Thx.
Furna
Check PM
cbhappy
Thank you. Isn't the line, "The sky above the port was the color of television, tuned to a dead channel." – William Gibson, Neuromancer?
Furna
It is ... it was 1984.
jdgesmlls
Hello, I am also getting the same error as everyone else:
Support live does nothing.
edit: board is a b550 tomahawk
Which version of MSI Center are you running? I have a B550 Gaming Edge WiFi, which has the same family controller chip (Nuvoton NCT6687x) as the Z490 GodLike and MSI Center 1.0.40.0 offered the LED FW 0.9 update. MSI Center 1.0.41.0 has since been released as well.
Furna
Check PM
