[SOLVED] MEG Z490 Godlike Dynamic Dashboard II not working and Corsair RAM RGB not showing up in Mystic Light after MB LED FW update in Dragon Center
Furna
The sky above the port was the color of television
thanks, unfortunately clicking update oled i only get "send command fail"
I am afraid you have to RMA the board ... if that software cannot "talk" to the OLED chip, it means the chip failed.
Sorry for that
jsolty72
Z390 Godlike. Cannot control dynamic dashboard, infinity and dragon logo do not light up. Live update and advanced scan says cannot find update in server.
Furna
That is a sign the software is not able to "speak" to the Dynamic Dashboard II controller chip ... not a good sign.
Anyway check PM in a few minutes; try the procedure and let us know the result.
Furna
Sorry my bad I mis-read your post; the tool I have the link to is for Z490 only.
acueva154102d3
Hello -- I have the same problem... everything is working GREAT, except Dynamic Dashboard II... :( they want me to RMA, but I just finished putting this thing together... please help ;(
Administrator
Check PM within few minutes to have a try.
wernerr15a902e7
Sorry to necro an old post, but looks like others are still running into the same issue! My Z490 Godlike OLED firmware is listing 0D, but after attempting the update, blank and nonfunctional, firmware still listed as 0D - any chance I can get the tool to reflash it? Thanks in advance!
Furna
Check PM
Sorry for late reply
brians141159102e9
Hello, I have a MSI Z490 and the lights on the board are frozen. The animated screen still works. When I open Dragon Center and click on motherboard, there’s a blank error that pops up. I just want the lights to work again
My Dynamic Dashboard II is not working. Only the temp is being displayed. This happened after I did the FW LED update in the MSI Center. My board is the z490 Godlike. Please help!
Furna
I am sorry this thread is about the "animeted screen" only.
I suggest you open your dedicated thread and try to be more precise in your description; what kind of lights? Do you mean RGB led or .. ?
Furna
If you can see the temperature on Dynamic Dashboard II the firmware is working fine ... I guess you cannot change it to show something different than the temperature ... this seesm to be MSI Center/Mystic Light related.
Nevertheless you have a private message.
Let us know if you solve the problem
brians141159102e9
Alright my apologies. The issue I’m having is the MSi dragon light up thing on the top left of the motherboard is frozen in purple/blue. Then on the bottom right of the board the “godlike” light up thing is frozen in yellow. I want to be able to have a full RGB board and not just still color. I provided pictures in this post.
Furna
As I wrote already this thread is only for Dynamic Dashboard II / animated screen ...
Your problem seems related to MSI Center/ Mystic Light not being able to change the theme of RGB ...
I suggest you open a dedicated thread
