briangooden6154a02e0
- Nov 23, 2020
So yeah, I have the same problem with the dynamic dashboard after all the updates. Can someone please explain how they fixed it, thanks.
check PMSo yeah, I have the same problem with the dynamic dashboard after all the updates. Can someone please explain how they fixed it, thanks.
So you know there is a solution and to whom ask for it.What is the point in having a forum if everyone is getting a PM for a solution?
Check PMdynamic dashboard wont alter using dragon centre mystic light...
Please check PMplz help myu Dynamic Dashboard is having same problem
Hey, I have The same problem, how did you fix it??? It`s driving me crazy!Hi,
as per the title after I upgraded my MEG Z490 Godlike motherboard's led firmware, I noticed the Dynamic Dashboard II is not powering up at all and do not react to any command in Dragon Center's Mystic Light Dynamic Dashboard II panel. Also the RAM is not available anymore in Dragon Center's Mystic Light.
I still can retrieve the MB LED FW version, so I think the hardware is still working and re-flashing is still possible.
Here my firmware/software versions
BIOS MS-7C70 1.2.0
MB LED FW LED_0F OLED_0D
Dragon Center 2.0.82.0
Mystic Light 1.0.0.92
Is there any method to re-flash/downgrade the motherboard's led firmware?
Any hint is appreciated.
Thanks
Luca Furna
BIOS MS-7C70 1.2.0
Thanks
Luca Furna
Check PMHey, I have The same problem, how did you fix it??? It`s driving me crazy!
Do you mind to show a picture of your motherboard with a Dynamic Dashboard II?same problem here with my x570 gaming pro carbon wifi
This is an English only forum; please follow forum rulesbuenos días, a mi me pasa lo mismo, el Dashboard no se enciende. He, desinstalado mystic light y volviendolo a instalar y nada, el resto de efectos de luz de la placa base funcionan y puedo cambiarlos pero el dashboard no. Gracias por la ayuda.
Justo be sure ... do you own a MEG Z490 Godlike motherboard?the same thing happens to me, the Dashboard does not turn on. I have uninstalled mystic light and reinstalled it and nothing, the rest of the light effects of the motherboard work and I can change them but the dashboard does not. Thanks for the help.
yes, at the beghining all work fine but after update something (I make a clean full instalation of windows 10 and all the drivers) the dashboard dont show anything.Justo be sure ... do you own a MEG Z490 Godlike motherboard?
