edengonzalez8150602cd
- Apr 1, 2021
As the title states, installing MSI Center on my MSI MEG Z590 Ace causes my cpu temps to spike between 15C-20C on idle. Only reason I want MSI Center is to use Mystic Light. As soon as I uninstall MSI Center and the MSI SDK and reboot my temps go back to normal. I tried blocking all MSI services and processes i found from startup but it still ramps up those temps. I set the lighting to what I want it and uninstalled it all for now.
Edit* SOLUTION
So I figured out my issue. So when you install MSI Center it does change the power plan, but this change alone is not what causes the temperature spike. If you use MSI Center as well as Corsair iCue an MSI plugin for MSI Motherboard is activated on iCue when installing MSI Center in order to control attached lighting to the motherboard (it does not control the on board rgb, just the stuff connected to the corsair header). So I went into iCue and disabled plugins and that brought down the CPU usage and temperature. Not sure who needs to fix this but there is an issue between these two programs.
Edit* SOLUTION
