[SOLVED] Mystic Light not showing up in Dragon Center
madse152c02d2
Try to install MSI Center now, currently the latest version is 1.0.20.0. And if you still encounter the same "blocking by antivirus..." thing, try the troubleshooting here: https://forum-en.msi.com/index.php?threads/time-to-upgrade-your-software-–-msi-center-bug-status.362779/post-2059269
Thanks for your response. Yes, I Installed MSI Center now. I had the same problem during installation, blocked by antivirus... In the forum I found the solution for the problem. Apparently, I had to update Windows 10 to the last release, and use the MSI center standalone installer (not the windows app) running as an admin. That worked fine and I could install the MSI center, but still no RGB, this time is because in the Futures module, after downloading and installing the Mystic Light 2.0.0.14 module it will not open.
fatedust
Survey Corps
FIRST LIEUTENANT
Hi. No, After several minutes, no response at all.
What if you uninstall Mystic Light and reinstall it?
Last resort is to reinstall MSI Center. Use MSI Center Uninstaller Tool to remove the GUI & SDK of MSI Center and open Registry Editor, delete MSI folder at Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Nod\MSI.
madse152c02d2
Hey man, Thanks for your help. I did everytime you told me but unfortunately the problem still persists.
fatedust
Survey Corps
FIRST LIEUTENANT
Sure, there it is.
I just find that you can update Mystic Light to v2.0.0.15, maybe a update and then restart the system can fix your problem?
Also, can you share the sticker on your RAM module and all connected storage device (SSD/HDD)?
madse152c02d2
Hi. I uninstalled the MSI center using the cleaning tool and reinstalled again with the last version of MSI center and Mystich Ligth. The problem persists.
My RAM is the Patriot Viper RGB https://viper.patriotmemory.com/pro...nce-memory-ram-viper-gaming-by-patriot-memory
The SSD is ssd xpg spectrix s40g https://www.xpg.com/us/xpg/610
Other RGB devices are Coolermaster Masterliquid ML120R with 4 fans connected to the board using the Coolermaster RGB controller.
https://www.coolermaster.com/catalog/coolers/rgb-accessories/rgb-led-controller/
This controller has one ARGB (3pin) and one RGB(4pin) port connected to the motherboard with cables. The controller also has a USB port connected with an internal cable to an internal USB port in the motherboard for configuration. I already test uninstalling and reinstalling the MSI center with the controller and fans disconnected, and all third party RGB software uninstalled (XPG, PATRIOT)
Last RGB device is the RTX3070 Aorus Master. I installed the RGB fusion software to configurate the RGB and built in LCD display. When I realize that Mystic Light was not working, I uninstalled the RGB fusion software using IOBtuninstaller and CCleaner. I also tracked down every Gigabyte related folder to clean it.
