Something wrong with BIOS Upgrade
jjdd815ae02e1
I have Z590-A Pro with BIOS E7D09IMS.100.
I download 7D09v13 and want to upgrade.
I follow the document,
I enter BIOS, I click M-Flash, Then I click YES
Now I see BLANK SCREEN.
What should I do now? I dare not to reboot.
Don't worry, there are several more steps before any updating/flashing begins. You can reboot just fine.
I would try to check the other graphics outputs that you have. Maybe the picture is displayed there for some reason.
jjdd815ae02e1
Yes, I have a GPU plug in and I set the default is IDG not PEG. and I do switch to GPU card and still no output.
and the reason I want to upgrade BIOS is I want to do DDA but got error that BIOS does not support SR-IOV
And I hope new version will support that.
And another issue is document didn't say USB need to format as FAT32 or NTFS. Maybe my USB has wrong format?
I am thinking of shutdown and remove GPU to make life simple
Can I reboot now? will it go back to normal mode if I reboot? I think the flash not happen yet
