Spare parts cover and battery for GS63 7RD Stealth
javiersaine158a02dd
Hello, I currently have the device described in the description but the battery no longer works, the representative here in Colombia tells me that msi does not have production for the change, I also have problems with the opening hinge that broke and the entire cover must be changed and the answer is also that the msi supplier does not have the parts, very worrying because I have no solution and with this I hesitate to consider buying the brand again. Please help!!!! my email is javiersainea@gmail.com
Thank you
darkhawk
GS63 is quite old at this point.
Best option is to look at ebay and buy parts there to repair it yourself. The battery really isn't that difficult. I did it on my GS73 that I had, was mostly just the screws on the bottom, a few inside for the battery, and the plug removal.
As far as the hinge, this is almost always an issue with the laptops.
Best again I can suggest is going to ebay and finding a proper back for it and replacing that.
