Spatium M482 write speed problem
deylon128a02a4
Hello i recently checked the read and write speed for my M482, the write speed is so low, i dont know why this is.
Hello i recently checked the read and write speed for my M460, the write speed is so low, i dont know why this is.
Within Specs infact that is over Performing if anything Should be Upto 4900MB/s Read and Upto 4400MB/s Write so its over Performing if anything here its not Low its actually Higher then Expected.
is it a M460 and not a M480 as the reads on that are more in line with the 480 Version?
Apologies, it's the Spatium M482. Advertised as 7300 read and 6400 write
Board: GIGABYTE B760M DS3H AX DDR4
BIOS: Version F16
VGA: RX 7800XT
Riser Cable PCIE Gen 4 x16
PSU: Corsair RM750e
CPU: Intel Core i5-13600KF
MEM: Corsair Vengeance LPX 32GB (2 X 16GB) DDR4 3600
BIOS: Version F16
VGA: RX 7800XT
PSU: Corsair RM750e
What M.2 port is it in
You will need to speak to Gigabyte and see if ther are any limations but I can tell you if it is on the Chipset controller it is running at correct speed
as it will not perform as well if on the Chipset compared to the CPU M.2 Controller
