Startup issues, Nightblade x2b 068TW
dragoon_panzer4
Hi there, I have had this problem in the past but up until last saturday it hasnt occured. When I go to shut down my computer it normally shuts down fine, after saturday when I disconnected everything to move things around and after attempted to turn on the PC, the fan would just come on and there would be no display, no boot sequence or anything; I also ran into the issue of the computer randomly locking up but have found the solution to that so far.
Now I have to wait a few hours with the power disconnected before I can boot my pc up again, I also notice the led's for the 'vga, ram and cpu' blink inside during the initial turn on sequence prior to it booting and not doing so. There is also a blue led that blinks after forcing the power off.
Now I have been told this is a problem with the OS and to do a factory reset to solve the problem, I was wondering if there are any other solutions to this issue, or a better way where I can cycle the power properly to boot the pc quicker.
For this symptom-There is also a blue led that blinks after forcing the power off:
It isI think this system is just into sleep mode.
1.Please refer it for disabling Sleep Mode In Windows 10
http://www.intowindows.com/how-to-enable-or-disable-sleep-mode-in-windows-10/
2.Please also check fast startup is must be "Check".
https://www.tenforums.com/tutorials/4189-turn-off-fast-startup-windows-10-a.html
If still, please provide serial number as below to us for this system you used.
Serial number on the back cover and on the box.
It is SOP how to check it as below link: It shhoudl be MSB106xxxxxxxxxx / 16 bits.
http://www.msi.com/page/warranty
My serial is MSB106FCS0104190
Today Thursday November 30th my system also just locked up. I had disabled sleep a couple months ago and fast start on Monday and the problems are still persisting. The blue led is only showing when I hold the power a few seconds after forcing off the power. If possible I would like to send it in.
