jedram415c302ea
- Jun 10, 2023
A few months after purchasing the Stealth 15M B12UE laptop, I started experiencing performance drops in games. Initially, I noticed that the processor frequency would drop from 3-3.3 GHz to 1-1.5 GHz, so I started using the Cooler Boost mode. Previously, I had the automatic fan control mode enabled. However, even in Cooler Boost mode, I continued to experience frequency drops. The temperatures, though, remained within normal limits. There may be occasional instances where the temperature slightly exceeds the norm for a fraction of a second, but there are no obvious temperature issues.
I'm not sure if the GPU performance drop is related to the CPU frequency decrease, or vice versa, or if the system reduces the performance of both components together. Following MSI support's recommendation, I uninstalled the graphics device drivers and installed the factory ones, and also reset the embedded controller, but it didn't help.
I also sent the laptop to a service center for fan replacement, but I don't remember if the performance issues started before or after that, so that might also be a factor.
These problems seem to arise after approximately 1-2 hours of gaming, and when I restart the laptop and allow it to cool down for a while, the performance drops occur within 30 minutes.
