Stealth 16 AI Studio A1VFG FPS Drop Problem
I’m using the Stealth 16 AI Studio A1VFG laptop, and I’ve been experiencing FPS drops while gaming. Normally, I don’t have any FPS issues in League of Legends and can play smoothly, but sometimes, when an animation like Mordekaiser’s R starts, or right after I recall back to base, the fans suddenly ramp up in auto mode and my FPS drops drastically to around 8–9 FPS.
The only temporary fix I’ve found is to unplug and replug the charger. After doing that, the system goes back to working normally, but this issue can happen multiple times in the same game.
I’ve also noticed the same problem in Marvel Rivals—even on low settings, it happens constantly. My guess is that either the CPU or GPU isn’t getting enough power, and when I reconnect the charger, it somehow resets the power delivery.
I haven’t been able to find the root cause yet. Has anyone else experienced something similar? What would you recommend I do?
Does the problem occur in the specific game only?
Try to monitor the CPU/GPU temperature when the fans suddenly ramp up and FPS drops to 8-9 FPS.
Also try to update BIOS to the latest version if you didn't update yet.
No, it occurs other games too.
It doesn't occur in a pattern so I couldn't monitor or record it. But I can say CPU 95 100 C degree, GPU 65-70 C degree.
BIOS updated to the latest version.
WHAT HAPPENED NEXT I M ALSO HAVING A SIMILAR ISSUE IT GETS SUDDEN FPS DROP WHILE PLAYING AND WHEN I REPULG THE CHARGER IT GETS NORMAL ONLY TEMPORARILY .....WHAT SHOULD I DO . I BOUGHT THIS LAPTOP NEARLY 9 MONTHS AGO....IS THERE ANYTHING THAT I CAN DO
Bro i don't know what can you do. I've been using it for 2 years. Two months ago, I sent laptop to an authorized service center for cleaning. After cleaning there were no problems for a while, but it started again two days ago. I don't know if there's a complete solution. If you find one, don't forget to write it here.
