Steam Redemption Reward
08/05/2021 i redeem my steam wallet code but till now i didnt receive any code, anyone can help me where i can direct send an email to MSI support to help me out my problem
dvair
Active member
SECOND LIEUTENANT
Give them a few days to process it. I just did one a while back and it took 4 or 5 business days for it to appear in the rewards menu.
vnv190153902d6
Hi Dvair, Thanks for advising. Did you encounter redeem code issue. Since I got from the MSI promotion but they code is not valid as I tried to put in steam wallet.
Any tips for help with this. Highly appreciated
dvair
Active member
SECOND LIEUTENANT
I had no problems with mine, but it was a while back. My code worked with no issue. Only resolution to any of this to a direct contact to MSI until they resolve it.
Alan J T
You need to check to see if your country allows Steam codes and that you also got sent ones for your region If you in say England Steam codes for the USA or JApan may not work for you.
Sometimes the promos are region locked and you will receive codes for that region. Or no codes at all if it is a regional thing.
nhtphuc1915c902f0
Hi everyone, I'm trying to redeem but there isnt a button "Relative Promotion" like in the guide. Does anyone encounter similar issue?
anhquannguyen203
Hi everyone i have redeemed a 12$ steam wallet code but i'm not received yet. It was 12 days since i redeemed, it's still awaiting. Please help, thank u
I tried to redeem my $ 12 code that I won but I get that some help mail has already been used, the code if it allows me to use it in my country
mcboyd154a02d7
Hi so the promotion is almost about to end soon should i email them (if that possible) i have been waiting from 10/31/21 an, its still under review it says?
mcboyd154a02d7
ty for the info but there is no email for me to use as much as i been loop back and froth through the tabs i did found a repaired hotline i guess but don't think that going to help me
mcboyd154a02d7
i found the phone number but right now they r piss me off i am providing them the only information i have and they r deny it then also left me with the little ps > not order details when in witch has all the information they ask for god dam it i am underling it for them now.
