Strange behavior with SATA disk drives on MSI MPG B850 Edge TI WiFi Motherboard
AlAldushi15db02ea
Hello dear Community!
I built initial version of my PC based on subject motherboard.
CPU: 8700G
Video card: to be continued :)
RAM: 64 G
2 TB M.2 with Windows, 1 TB M.2 with Linux
2 SATA drives (2.5") from my old notebook 1.75 TB
Initially I used 1 TB (also 2.5") drive and it was OK.
Then I added 2 more 1.75 drives and found that only one of them visible for system (even on BIOS level).
Then I found that both HDD are OK, but system want to see only one of them OR - don't see both. For me it looks random.
Now I connected only these 2 drives, then only one of them. And from start to start - it can be visible or not. On BIOS level and for sure for Windows and Linux systems.
Any idea what happening? Old SATA HDD is not a friend for hew hardware? As problem visible on BIOS level I expect it specific for Motherboard. Schrodinger's drive...
(In background: both 1.75 HDD perfectly works without any question in my Lenovo Legion notebook and from USB holder ...)
Updated to latest BIOS version. Same behavior.
When you feel on the drives with your hand (or maybe you hear it too), do they always spin up when you boot? So it's not that it would not spin up, it would be more of a BIOS issue? Then i would open a ticket with MSI. There were a couple of "disappearing drives" issues on those MSI 800-series AM5 boards before.
Thank you, got your point... I will check for this.
Let me do some set of tests to collect statistics - and, if you have some ideas what to do on my side - please provide your steps.
I suppose to do 10 cycles with cold startup - with one and two connected drives. Then - same after sleep mode. Good point (for MSI Developers :-)) ) - now it stable reproducible in my configuration. If it possible to enable and collect logs (for example) - I will provide all required information.
