Strange Boot Problem?!
  • Thread starter Thread starter Illerian
  • Start date Start date
I
Illerian
Guest
As of late my nForce system does not boot the first time I press the power button, fans and DB light up but no boot. If I turn off and on again it boots just fine.
When I had all the fans on the MB the DB showed
Red Green
Green Green
then I moved my fans to my digitaldoc 5 and it showed different
Green Green
Green Red
I suspected the power supply so I went out and got me a new 300W Zalman but it did not fix my problem!
Once I recycle power it works like a charm and no problems occur at all.
Oh, almost forgot, the power LED glows very faint!
Now I cant remember if this problem was solved on the old msg-board so I am asking again maybe?
Please help me, it is starting to bug the hell out of me!
hi
can you give us the data of this new psu for 5v and
3.3v,should be written on the side,looking for max
figures not peak
well its not the psu[better figures than some so called
400 watt ones]
what about the battery v bat
what os you using ,any add in cards,or things plugged
in ,try removing see if it goes away
my power LED light is faint compared with my hdd led. then again i did have to mod the connection because it was 3pin.
ive gota 300w psu and 2 case fans, i havnt had any boot problems however.
its best to try what wonkonoby said, strip your pc down to bare bones and see what card is causing your problems.
On my Abit Kt7a I once got a similar Problem after changing one of the fans and using another fan power connector. Maybe you changed something and the fans are drawing to much power (on first startup) ?
i would take out any PCI cards you have.... only have 1 HD on your system... no CDrom. and move all your fan's to the PSU not the mobo...
your mobo might be dieing. or something takeing to much power.
When you say does not boot the first time do you mean you get nothing on the screen ie. Bios identification?
If you do get that but then no OS load, I'd check your HD and cables, you could veryify a HD problem by booting initially to a floppy with Dos on it.
If you do not get initial Bios screen on turn on, then yes you have a problem although cannot see it being PSU as the board would be intialised before the fans etc.
Good luck
I get nothing on the screen, only thing I can detect is fans starting up and power LED glowing. DB light up as in the orginal post, thats it!
I'd say bios is not initialized and cpu is not started!
I have tried to remove all the add in cards, only have one Gainward GF4 4200 in AGP.
Next I will try to disconnect all fans and see if that helps. I got 5 80mm Zalman fans in my Lian Li case, but they have not been a problem before so I dont see why they should now!
Thanks for all the advice so far, hope I can solve this!
You know, I had/have a similar problem. When I would boot up from a complete power off (unplug cord or turn off PS at the main switch) I would make it through the BIOS POST up until it tried to detect drives, etc. Then it would sit quietly until I hit the reset button. On reboot it would move through flawlessly, detect everything, and boot up without comment. Then one night the PSU croaked after I powered it down and unplugged the system before an electrical storm. After replacing the power supply, now it only pauses for about 5 minutes on a cold start before completing bootup. Im still working on finding a final culprit/solution.
