- Aug 29, 2010
Hi MSI groupies!
First of all I'd like to say that it's nice to see that MSI HAS this kind of forum.
Now, here's what brought me here:
I have this new system, a i3 550, 2* 1 GB RAM and a MSI H55 Board (BIOS 1.3).
1. Question:
The system is auto-determined to work without VT-d. I'm working in this machine, it has to be 100% reliable, I don't need any special features... Is disabling this OK?!?
2. The Problem:
I had some struggle with installing the OS (Ubuntu & XP 32bit). Finally, it worked (by change?!?). These problems were strange ones, like hang-ups, false .zip file extraction etc.
I checked the most important components (HDD, RAM, CPU). The strange thing is that when I DIsable Spread Spectrum, Memtest (newest version) does NOT start at all, it freezes right at the beginning. MS Office has some kind of system check tool, this one also says that there's some bad news from the RAM. If I Enable Spread Spectrum, everything works fine. The same for prime95: Without SS, it runs bad.
So what is this? It should be the other way round?!?!?
The RAM Settings are "Auto" set to (1066, but it's spec'd to 1333):
7-7-7-16 - 59 - 1
CL-tRCD-tRP-tRAS - tRFC - CR
Could it be possible, that there happened some typo? I couldn't explain it otherwise, it would be interesting to hear from other H55 users!
The "RealTemp 3.4" Tool also shows that no matter of SS, the clock varies around +-0.5 GHz (idle). If SS is disabled, the clock "BIAS" is round higher (~2.5 GHz). If SS is enabled, it's ~1.7GHz.
Right at the beginning, I flashed the BIOS to the 1.3 version (newest) with the BIOS-own tool. Right after flashing, I got this "Checksum Error" message and it told me to go into the BIOS. Then, I changed the settings to my needs. After exiting, everything worked. I also downloaded the BIOS again and flashed it a 2nd time, the same message.
I don't know... May be the mainboard is somehow damaged?
1. Question:
2. The Problem:
7-7-7-16 - 59 - 1
