Strange Noise, GP65 Leopard
amankebron158402e5
Recently I noticed a strange scratching noise coming from the inside of the laptop (MSI GP65 Leopard 95D) I bought it just 5 month back
here is the link to listen to the noise
Help Needed, What do you think the reason is?
Thanks In advance
Crazydonkey
Active member
SECOND LIEUTENANT
To confirm if the problem is related to fan noise, you can try to disable the 2 fans by applying advanced fan mode in Dragon Center > click the gear to set all level's fan speed to 0.
If the sound still remains, try to disable C-state in BIOS.
If the sound still remains, contact msi directly for further check.
